View the VRF Configurations
Use the following command to view VRF configurations.
  1. Enter Privileged EXEC mode:
    enable
  2. View the VRF configuration:
    show ip ospf vrf WORD<1-16>
Switch:1#show ip ospf vrf virtualrandf1
                        OSPF General - VRF virtualrandf1
            RouterId: 192.0.2.1
           AdminStat: disabled
       VersionNumber: 2
    AreaBdrRtrStatus: false
      ASBdrRtrStatus: false
      Bad-Lsa-Ignore: false
      ExternLsaCount: 0
   ExternLsaCksumSum: 0(0x0)
          TOSSupport: 0
    OriginateNewLsas: 0
           RxNewLsas: 0
          TrapEnable: false
  AutoVirtLinkEnable: false
     SpfHoldDownTime: 10
Rfc1583Compatibility: disable
              default-metric :
                         ethernet - 100
--More-- (q = quit)
Variable definitions
The following table defines parameters for the show ip ospf vrf command.
Variable
Value
vrf WORD<1-16>
Specifies a VRF by name.
